- Most capable Wrangler yet delivers new iconic seven-slot grille, new active safety features, standard side curtain airbags and 12.3” Uconnect touchscreen radio.
- Iconic Wrangler exterior features windshield-integrated trail-ready stealth antenna, five all-new wheel designs and multiple open-air freedom options, including exclusive Sky One-Touch power top.
- Refined interior with more technology and amenities, including available 12-way power adjustable front seats, all-new instrument panel featuring Uconnect 5 system with state-of-the-art 12.3” touchscreen radio and standard wireless Apple CarPlay and Android Auto.
- Wrangler now delivers standard Drowsy Driver Alert, Lane Departure Warning and Traffic Sign Information.
- The 2024 Wrangler 4xe is supporting the Electrification strategy of Jeep brand and will be the major player version in Europe.
The new 2024 Jeep® Wrangler, the most off-road capable and recognized SUV in the world, is arriving to Europe with an unmatched combination of off-road capability, authentic Jeep design, open-air freedom, advanced powertrain, superior on- and off-road dynamics and a host of innovative safety and advanced technology features.
The latest evolution of the iconic SUV adds greater capability, new technology and advanced safety features, while staying true to the Wrangler formula and delivering the freedom to go anywhere and do anything.
For the new model, the Jeep brand is taking the Wrangler capability game to new heights with its first full-float Dana rear axle. Inside, customers get to experience more comfort and safety, with a new interior featuring standard 12-way power front seats, standard 12.3-inch Uconnect 5 touchscreen radio and standard side curtain airbags in the first and second rows.
The Jeep Wrangler is the archetypal adventure hero, embodying the spirit and the soul of the Jeep brand, since its introduction, Jeep sold five million Wranglers around the world, setting new levels of 4x4 capability with each new generation.
Building on its legacy of freedom and adventure, the new Wrangler is a testament to its loyal enthusiast fan base.
“The new 2024 Jeep Wrangler is enhancing his role has the “hero model” of Jeep line-up by combining the legendary capability with more technology, comfort, and safety features. This is a no-compromise combination enhanced by the freedom of our 4xe technology” said Eric Laforge, Head of Jeep® Brand in Europe.
In Europe, the 2024 Jeep Wrangler will be available in Sahara and Rubicon models. The first vehicles will start to arrive in European Jeep dealerships in the first half of 2024.
Zero Emission Freedom: 4xe is the new 4x4
The new 2024 Wrangler 4xe builds on the Jeep brand’s goal of Zero Emission Freedom in its effort to become the greenest SUV brand in the world, building the most capable and sustainable Jeep SUVs.
Jeep Wrangler 4xe models, along with a range of electrified powertrains, will play a role for the Jeep brand as it follows the Stellantis Dare Forward 2030 strategic plan, in which electrified, and more efficient propulsion systems help Stellantis cut its global carbon footprint by 50% by 2030 and lead the transportation industry by achieving net carbon zero by 2038. By 2030, 100% of Jeep vehicles in Europe will be fully electric.
Legendary go-anywhere 4x4 capability: Most capable SUV ever without compromise
- The new 2024 Jeep Wrangler 4xe delivers legendary off-road capability and it is the most capable ever with best-in-class performance thanks to the combination of a powerful front combustion engine and surprising rear electric propulsion that delivers the torque on demand. It is equipped with two advanced 4x4 systems:
- Rock-Trac full-time transfer case
- Selec-Trac full-time transfer case
- Crawl ratios of up to 77:1
- Water fording of up to 760mm at a maximum speed of 8 kph
- Uncompromising approach, departure and breakover angles and ground clearance for the highest spec:
- Approach angle: up to 36.6 degrees
- Breakover angle: up to 21.4 degrees
- Departure angle: up to 31.8 degrees
- Ground clearance: up to 253 mm
Every Wrangler model’s Trail Rated badge reflects an unmatched specification list that includes Dana solid front and rear axles, two-speed transfer case, traction control, tow hooks, four-wheel disc brakes, four skid plates and a minimum tire size of 81 cm of diameter. The new 2024 Wrangler continues to raise the bar with the all-new next-generation Dana 44 HD full-float rear axle on Rubicon models.
Now, Wrangler customers can get full-float axles, typically found on heavy-duty commercial trucks, straight from the factory. Wrangler Rubicon’s first full-float rear axle design consists of a wheel hub assembly that is separate from the axle shaft, with a spindle bolted to the axle tube that supports the wheel hub via a pair of wheel bearings. By using a full-float axle design, the weight of the vehicle is transferred to the axle tube rather than the axle shaft itself. Thus, the axle shaft is subjected only to torsional loads, with its sole function being to transmit power to the wheel hub. This makes the axle stronger and more robust.
Legendary capability for Wrangler Rubicon comes from a full list of off-road features, including:
- First Dana 44 HD full-float solid rear axle
- Rock-Trac part-time transfer case with 4:1 4LO ratio
- Electronic front sway-bar disconnect
- Tru-Lok front- and rear-axle lockers
- 17-inch aluminum wheels with BFGoodrich mud-terrain tires
Proven body-on-frame design is the foundation for legendary Jeep capability
Using a body-on-frame design and featuring a finely engineered five-link suspension system, the new 2024 Wrangler delivers unrivaled capability, refined on-road dynamics and advanced safety features.
To protect critical vehicle components while on the trail, including the fuel tank, transfer case and automatic transmission oil pan, Wrangler features four skid plates.
The use of lightweight, high-strength aluminum closures, including the doors, door hinges, hood, fender flares, windshield frame and magnesium swing gate, helps reduce weight and boost fuel economy.
For 2024, Wrangler continues to use the proven five-link coil suspension setup. Wrangler’s front suspension features two upper and two lower high-strength steel control arms for longitudinal control and a cross car track bar for lateral axle control.
The five-link rear suspension features a similar layout to the front suspension, with two upper and two lower high-strength steel control arms for longitudinal axle control, and a track bar for lateral axle control.
The front and rear full-width high-strength steel track bars are positioned to control lateral movement of the axle with minimal angle change during suspension travel.
The shocks are tuned for optimum balance between on-road handling and legendary off-road capability, delivering ideal ride comfort, body-roll control, and dynamic handling.
On Wrangler Rubicon models, an electronic front sway-bar disconnect is featured to provide additional wheel travel when the terrain calls for it.
More than 85 available advanced safety and security features
Safety and security were paramount in the development of the new 2024 Jeep Wrangler, which offers more than 85 available active and passive safety and security features. Standard on all models for 2024 are first- and second-row side curtain airbags, which complement standard driver and passenger front airbags and front seat-mounted driver and passenger side airbags.
For the 2024 model year, Wrangler features second-row outboard seatbelts with pretensioners and load limiters, as well as structural improvements for side-impact performance
List of standard ADAS (advanced driver’s assistance system) includes Forward collision warning and advanced cruise control with stop, blind spot detection with rear cross-path, as well as the brand-new Drowsy Driver Alert, the Lane Departure Warning, and the Traffic Sign Information (available from Q1 2024). ParkSense front and rear park-assist system come standard on all price classes, while Sahara features a ParkView rear backup camera with dynamic grid lines and Rubicon features the offroad camera with front and rear view. Traction control and electronic stability control (ESC) with electronic roll mitigation come standard on all models.
Iconic Jeep Wrangler design: new grille, wheel designs and multiple open-air freedom options
The new 2024 Jeep Wrangler builds on a sculptural design aesthetic that is immediately recognizable with its traditional Jeep design cues. The 2024 Wrangler’s iconic seven-slot grille wears an updated look with black textured slots, neutral gray metallic bezels, and body-color surround (platinum silver slots and bezels on Sahara). Slimmer both visually and literally, the new grille’s black textured vertical slots improve cooling.
A new trail-ready stealth antenna integrated into the front windshield replaces the previous steel mast antenna, streamlining Wrangler’s appearance and eliminating brush or tree limb snags on the trail. Five new standard and optional wheel designs, from 17- to 20-inch diameter, freshen Wrangler’s rolling stock.
Multiple open-air freedom options, including two available standard hardtops (black and body color), exclusive Sky One-Touch power top, Sunrider for Hardtop, and dual-door group with half doors, mean there are multiple door, top and windshield combinations so Wrangler customers can customize their off-road adventure to their specific needs.
Wrangler is also available in 10 eye-catching exterior colors, including: Anvil (NEW), Earl, Firecracker Red, Granite Crystal, Silver Zynith, High Velocity, Hydro Blue, Sarge, Bright White and Black.
Authentic interior design boasts premium features and technology
The new Wrangler’s refined interior is loaded with premium features and technology along with Jeep functionality and versatility. The heritage-inspired center stack features a clean, sculpted form that complements the horizontal dashboard design. A wrapped instrument panel features new soft-touch surfaces, in fabric or polyurethane, with contrast accent stitching. New AMPS bracket provisions are now featured on top of the dash.
Standard on all models is improved hands-free voice recognition, which now uses microphone array technology. On Rubicon and Sahara, a standard premium cabin package adds acoustic front glass, thicker carpet and additional sound deadening foam in the windshield header, front cowl, and B-pillars for a quieter ride.
An all-new 12.3-inch touchscreen – the most advanced and largest display ever offered on Wrangler – houses the fifth-generation award-winning Uconnect 5 system and sits prominently atop the center stack, right above the new slim rectangular inboard air vent. The outboard air vents retain their signature circular shape.
Uconnect 5 delivers operating speeds that are five times faster when compared to the previous generation. By using an Android operating system and over-the-air (OTA) updates, Uconnect 5 brings flexibility that will allow the system to continuously evolve to offer new content, features and services.
The new Wrangler’s Uconnect 5 system offers more connected services and features for unmatched ease of use. The suite of system highlights includes:
- 12.3-inch digital touchscreen (NEW)
- Five user profiles plus a valet mode – customizable music preferences, apps, seat position, mirror angles and climate comfort levels (NEW)
- Wireless Apple CarPlay and Android Auto
- Fully customizable home screen for quick access to frequently used features and one-touch operation (NEW)
- Simultaneous connectivity for two Bluetooth-enabled phones (NEW)
- Alexa Home to Car functionality to include in-vehicle Alexa virtual assistant with natural voice capability and Car to Home features
- Uconnect mobile app
- TomTom navigation with predictive search, natural speak and live traffic updates
- Maps OTA updates at the push of a button for Uconnect NAV system (NEW)
- 4G LTE Wi-Fi hotspot to connect up to eight wireless devices
The new Wrangler is well-equipped to keep vehicle occupants connected while on the go. Functionality is enhanced for front-row passengers with standard dual USB Type C ports that allow devices to charge up to four times faster. The Wrangler delivers a total of up to seven USB Type A and Type C ports for both rows. Standard 12-volt accessory outlets are located throughout the new Wrangler and a 230-volt AC outlet is available to power select three-pronged home electronics.
Wide range of new connected services
The new Jeep Wrangler offers a wide range of connected services in several packages, providing customers with even more assistance, comfort, and entertainment. Designed to accompany customers on a daily basis, on every road and every path, these services offer rich and original experiences.
- New services to prepare journeys and save time and money.
The "Send&Go" function in the JEEP ® app enables pre-recorded journeys to be sent directly from the smartphone to the connected vehicle's on-board navigation system. The vehicle is ready to go without the customer having to take any further action once in the vehicle.
Whether at public charging stations or at home, charging the electric battery by selecting the charging times on the JEEP ® app on the smartphone gives customers more free time and enables them to manage their budget more effectively.
- On-board navigation is offering new services to support drivers on all roads and in all circumstances.
Thanks to all the information provided by the on-board navigation system, driving has never been safer or more stress-free. Customers benefit from the latest news on road conditions, including weather alerts, traffic alerts, speed camera locations also thanks to the automatic over the air map updates. They can also search for all kinds of points of interest directly during the driving, searching on the onboard infotainment system or simply using the voice, asking Alexa Voice Service for the information needed.
- Connected services that make daily life easier for customers, thanks to remote control functions.
Who has never forgotten to lock their car doors? Thanks to remote control functions, there's no need to retrace your steps. Everything can be managed remotely, with just one click on the smartphone, via the JEEP ® app. It is possible to turn on your lights to find the vehicle in a crowded car park, lock and unlock the vehicle doors and trunk, or check the doors’ status to be sure the vehicle is properly locked.
Thanks to the mobile app is it also possible to remotely activate or schedule the charging based on the residual battery level and precondition the new JEEP ® Wrangler 4xe in order to always find the perfect climate in the cabin before each trip.
- Trip Report: a feature to always monitor the driving style.
With the JEEP® app, customers can access a range of information about the journeys they make, checking their driving style, fuel and battery consumption, average speed, number of braking and much more, to always know how they drove during each trip and improve their eco-score for the next ones.
The new standard = more standard equipment
For 2024, the Wrangler lineup boasts more standard equipment across the model lineup, including:
Sahara
- New 18’’ wheel design
- 12.3-inch touchscreen radio
- Body color hard top
- LED lamps (front, rear, fog)
- Deep tint sunscreen glass
- McKinley leather trimmed seats
- Heated front seats and steering wheel
- Power 12-way adjustable front seats
- 9-speaker Alpine Premium Audio
- Keyless Go and Passive Entry
- Rear backup camera
- Front and rear parking sensors
- Gorilla Glass
- Security Alarm
- Black tubular side steps
- Lane departure warning (available from Q1 2024)
- Drowsy Driver Alert (available from Q1 2024)
- Traffic Sign Information (available from Q1 2024)
Rubicon
- New 17’’ wheel design
- Black hard top
- Nappa seats with leather inserts
- Offroad camera
- Gorilla Glass
- Security Alarm
- Auxiliary switches
- Dana 44 HD full-float rear axle
- Sway bar disconnection
Advanced propulsion systems combine power and efficiency
The most advanced powertrain ever developed for a Jeep Wrangler maximizes efficiency while delivering up to 51 km of pure-electric drive in the WLTP city cycle (pre-homologation values).
The Jeep Wrangler 4xe powertrain integrates two electric motors and a 400-volt battery pack with a fuel-efficient, turbocharged, 2.0-liter four-cylinder engine and TorqueFlite eight-speed automatic transmission. This configuration maximizes the efficiency of the hybrid propulsion components and mates them with the Wrangler’s world-renowned and proven driveline.
New for 2024, all Wrangler 4xe models offer a Jeep 4xe Power Box that features four 230 Volt outlets, allowing the battery pack to power external devices such as phones and tablets.
Key output of the Wrangler 4xe powertrain includes 380 horsepower (280 kW), 637 Nm of torque* from the following components:
- 2.0-liter turbocharged I-4
- Engine-mounted motor generator unit
- Transmission-mounted motor generator unit integrated into eight-speed automatic transmission
- 400-volt, 17-kWh, 96-cell lithium-ion, nickel manganese cobalt battery pack
The Jeep Wrangler 4xe’s E Selec modes allow the driver to tailor the hybrid powertrain to best suit each trip, whether it is filling the needs of most daily commutes in pure-electric operation, a night on the town or quietly exploring nature off-road.
- Hybrid: The default mode blends torque from the 2.0-liter engine and electric motor. In this mode, the powertrain will use battery power first, then add in propulsion from the 2.0-liter turbocharged I-4 when the battery reaches minimum state of charge
- Electric: The powertrain operates on zero-emission electric power only until the battery reaches the minimum charge or the driver requests more torque (such as wide-open throttle), which engages the 2.0-liter engine
- eSave: Prioritizes propulsion from the 2.0-liter engine, saving the battery charge for later use such as EV off-roading or urban areas where internal combustion propulsion is restricted. The driver can also choose between Battery Save and Battery Charge during eSave via the Hybrid Electric Pages in the Uconnect monitor.
Last Call for 2.0-liter turbocharged I-4 engine
To meet the demand of customers for a traditional powertrain, a limited batch of the 2024 Wrangler 2.0-liter turbocharged I-4 engine will go on sale in selected markets such as Germany, Italy, Poland, and Spain.
The 2.0-liter turbocharged inline four-cylinder engine with engine stop-start (ESS) is rated at 272 horsepower and 400 Nm of torque and mates to a standard eight-speed automatic transmission.
Using a twin-scroll, low-inertia turbocharger with an electronically actuated waste gate for exceptional responsiveness and performance, the 2.0-liter I-4 engine features a turbo mounted directly to the cylinder head for improved durability. A dedicated cooling circuit lowers the temperature of the intake air, throttle body and turbocharger.
The 2.0-liter turbocharged I-4 engine, which meets European Euro 6D-Final emissions standards, is part of the Global Medium Engine architecture family and features Double Overhead Camshafts (DOHC), dual independent camshaft timing, and a cooled exhaust gas recirculation (C-EGR) system. This combination of technologies enables high levels of performance and reduces fuel consumption.
The 2024 Wrangler 2.0-liter turbocharged I-4 engine will be available in Sahara and Rubicon models as well.
Jeep Wave customer care program
The Jeep Wave customer service program is available to the entire Jeep brand lineup. The premium owner loyalty program is filled with exciting benefits and exclusive perks, including:
- Two years of worry-free maintenance at Jeep dealerships
- 24/7 support via phone or online chat
- Vehicle protection including 24/7 roadside assistance and first-day loaner coverage
- VIP access to select exclusive Jeep brand events.
*Values defined according to the WLTP combined cycle, measured by the manufacturer on pre-approval tests and which may be subject to change following final type approval
